tu008 Posted October 24, 2010 Share Posted October 24, 2010 (edited) Hi , I am using a displace map in vray map slot......there is some problem in where the edges are...pls help... Edited October 24, 2010 by tu008 Link to comment Share on other sites More sharing options...
abmitalia Posted October 24, 2010 Share Posted October 24, 2010 Clean up your model ( boolean is the last way to model this simple geometry ) and than map it right and you wan't have problems any more. RK Link to comment Share on other sites More sharing options...
aristocratic3d Posted October 24, 2010 Share Posted October 24, 2010 Yes, problem is with the model. avoid Boolean. Link to comment Share on other sites More sharing options...
Alyosha Posted October 26, 2010 Share Posted October 26, 2010 if you're using max and if you absolutely have to use boolean (dont use it for simple models like this though!!!) you can also select all the polygons after you've done the boolean and click "retriangulate" might fix some issues Link to comment Share on other sites More sharing options...
tu008 Posted October 27, 2010 Author Share Posted October 27, 2010 Guys I have not used boolean,I just imported from cad,extruded and converted to editable poly. Displacement is doing the problem but how to solve it? Its just a single wall of a large project. Please find the attached file. Link to comment Share on other sites More sharing options...
