jophus14 Posted October 25, 2010 Share Posted October 25, 2010 What is the best way to optimize vertices when importing a CAD file into Max? I have a logo that I exported out of Illustrator as a CAD file and imported into Max as a spline and there are way too many vertices. How can I cut down the number of vertices in the spline yet retain the shape of it? Thanks. Joseph Skowron Link to comment Share on other sites More sharing options...
Fooch Posted October 25, 2010 Share Posted October 25, 2010 You can bypass cad and go straight from illustrator to max. That might help. Make sure you save the ai file as an older version (I normally go for v3 etc) Link to comment Share on other sites More sharing options...
-MerlyN- Posted October 26, 2010 Share Posted October 26, 2010 there's a shape normalize modifier in max. try that one. Link to comment Share on other sites More sharing options...
jophus14 Posted October 26, 2010 Author Share Posted October 26, 2010 You can bypass cad and go straight from illustrator to max. That might help. Make sure you save the ai file as an older version (I normally go for v3 etc) That is exactly what I had to do. It still took a little bit of tweaking once in Max but importing the AI file into Max came in the cleanest. Thanks. Link to comment Share on other sites More sharing options...
