Musitektus Posted July 8, 2004 Share Posted July 8, 2004 I'm having a problem with an imported raster image brought into VIZ Render 2005 from ADT2005. The image is an aerial site photo placed underneath the building model. It displays correctly in the viewports, but when the view is rendered from a camera view (for an animation) the image is flipped backwards. When I uncheck 2-sided materials in render options, it corrects the problem... However, for the building to render correctly (due to surface geometry that I drew in the building) I must have it checked. Any help as soon as possible would be very much appreciated. Thank you. Todd The Larson Group, Colorado Springs Link to comment Share on other sites More sharing options...
Videha Posted July 8, 2004 Share Posted July 8, 2004 render each alone in Render Elements Link to comment Share on other sites More sharing options...
Ras Posted July 8, 2004 Share Posted July 8, 2004 From what you say it sounds like you have problems with your normals? Try going into sub-object mode and flipping som faces on the ground to see if that makes a differende... Link to comment Share on other sites More sharing options...
