memol58 Posted October 27, 2010 Share Posted October 27, 2010 how can set the amount of objects visibility in reflection? Link to comment Share on other sites More sharing options...
mu_688687 Posted October 27, 2010 Share Posted October 27, 2010 Its not Reflection its Refraction visibility and invisibility can be obtain only through Refraction node. Link to comment Share on other sites More sharing options...
memol58 Posted October 27, 2010 Author Share Posted October 27, 2010 for example wanna set the roofs reflection in glass . to less visible than other objects in glass (roofs have less effects on glass reflection) Link to comment Share on other sites More sharing options...
mu_688687 Posted October 27, 2010 Share Posted October 27, 2010 You cann't set reflection for particular object you cann't change its index for particular object. Link to comment Share on other sites More sharing options...
dimosbarbos Posted November 6, 2010 Share Posted November 6, 2010 I guess you can use the channel refraction during compose that would reduce the reflection Link to comment Share on other sites More sharing options...
John Dollus Posted November 6, 2010 Share Posted November 6, 2010 render it twice - once like you have it and once with the roof object properties set to not reflect - then composite in post Link to comment Share on other sites More sharing options...
neil poppleton Posted November 6, 2010 Share Posted November 6, 2010 Agree composite images, should give you full control of what result you require. Link to comment Share on other sites More sharing options...
