Christiansltd Posted October 27, 2010 Share Posted October 27, 2010 Hi, I am teaching myself after effects, I am just having one issue, when rendering my final animation it is saving as a file that is way to large, is there a format to save to that keeps the quality but also reduces the file size. Thanks in advance for any tips Link to comment Share on other sites More sharing options...
aaronrumple Posted October 27, 2010 Share Posted October 27, 2010 Quicktime Mov's export pretty well from After effects. Try the H264 compression. Link to comment Share on other sites More sharing options...
hockley91 Posted October 27, 2010 Share Posted October 27, 2010 I agree with Aaron. The H264 compression has looked great in my opinion and has a good file size. I have found the 1280x960 format in .mp4 sluggish with Quicktime so I usually convert to .WMV with "iOrgSoft Video Converter" and play through Windows Media Player without much noticeable loss in quality. Link to comment Share on other sites More sharing options...
erickdt Posted October 28, 2010 Share Posted October 28, 2010 If you're planning on editing your AE compositions in Premier I'd suggest you not export them at all and instead import the AE comps directly into Premier. This establishes a link between the two files so if you make anymore tweaks on you AE comp it will automatically update itself in your Premier timeline. E Link to comment Share on other sites More sharing options...
Craig Ramsay Posted October 29, 2010 Share Posted October 29, 2010 erickdt said: If you're planning on editing your AE compositions in Premier I'd suggest you not export them at all and instead import the AE comps directly into Premier. This establishes a link between the two files so if you make anymore tweaks on you AE comp it will automatically update itself in your Premier timeline. E That's awesome... I had no idea you could even do that! Thanks for the tip Link to comment Share on other sites More sharing options...
PuffinViz Posted November 1, 2010 Share Posted November 1, 2010 Thanks for the tips on what compression you guys use, this just helped me out of a tricky spot Link to comment Share on other sites More sharing options...
