trhoads Posted July 8, 2004 Share Posted July 8, 2004 I am modeling in AutoCad, and File Linking to 3dVIZ 3i. I have arc smoothness in AutoCAD set very high, and Interpolation in VIZ set very high, but my arcs always come out very segmented. Tessolation can not be the solution from VIZ, due to the solids being modeled in AutoCAD. Anyone have a way to fix this problem. This plagues me on a few projects, this is an old example, but I need to fix it on a much larger project where it is very noticable. Any help is greatly appreciated. Link to comment Share on other sites More sharing options...
Chad Warner Posted July 8, 2004 Share Posted July 8, 2004 Not sure with Viz 3i, but check for the ACIS surface deviation setting...the lower the number, the more segments per curve. You can also try the curve step settings. -Chad Link to comment Share on other sites More sharing options...
Onslaught Posted July 8, 2004 Share Posted July 8, 2004 Set - 'dispsilh' = 1 Set - 'facetres' = 10 hope this works Link to comment Share on other sites More sharing options...
Tim Nelson Posted July 8, 2004 Share Posted July 8, 2004 Yea its usually the surface deviation setting on your file link settings. Link to comment Share on other sites More sharing options...
William Alexander Posted July 8, 2004 Share Posted July 8, 2004 Isolate the problem walls on a new layer, relaod (just that Layer/s) with a very low ACIS deviation value, then the crown moldings won't be 10 million faces to get a smooth curve in viz. By chance your not using ADT and the alcove is a subtractive wall modifier? Thats an entirely different can of worms. WDA Link to comment Share on other sites More sharing options...
trhoads Posted July 12, 2004 Author Share Posted July 12, 2004 Thank you all for your help. The surface deviation setting was the correct fix. I appreciate your time and assistance. I am not using ADT, that is a can of worms I am not familiar with. Link to comment Share on other sites More sharing options...
