padre.ayuso Posted November 5, 2010 Share Posted November 5, 2010 I'm sure this has come up before, but could not find the thread that deals with this. When I try to export my files from Max 2010 to FBX it usually gets stuck during the export and I have to re-start 3DS Max. This happens only on large files. I can export to 3DS and export to DWG, however I know that FBX is more accurate. The other problem with 3DS and DWG is that large objects with a lot of faces are not exported so I end up with incomplete exported files. Does anyone know what causes this problem or what setting I'd have to make sure is set to successfully export files to FBX? Thanks! Link to comment Share on other sites More sharing options...
padre.ayuso Posted November 19, 2010 Author Share Posted November 19, 2010 I'll answer myself on this in case anyone else runs into this problem. Interesting as it might be, it got solved in the new FBX Export plug-in 2011, which seems to work better overall and you can download this from the Autodesk website. Cheers! Link to comment Share on other sites More sharing options...
