sygboe Posted November 11, 2010 Share Posted November 11, 2010 Hi, i have several copied and rotated blocks in a drawing. all i want to do is change the location of the basepoint, without the contents of the block then moving the same amount. also i want to achieve this without a lisp and coding etc, i only have autcad lt. i simply cannot believe that this is so hard to achieve. i am a very good cad user too, and hate when i hit a brick wall will such simple seeming tasks. in sketchup this would be a sinch Link to comment Share on other sites More sharing options...
neil poppleton Posted November 11, 2010 Share Posted November 11, 2010 You just simply make the block again with the new base point and it will update all the other blocks. It asks when you give the same name to block to redefine. Link to comment Share on other sites More sharing options...
sygboe Posted November 11, 2010 Author Share Posted November 11, 2010 thanks for the reply, but this doesn't work. it just does the same thing as if you moved the basepoint inside the block. all the blocks change position. i was excited for about 2 mins then Link to comment Share on other sites More sharing options...
