difficult geometry
raymarcher
I have imported a model from autocad that is difficult to cleanup, see the screenshot attached, I have double faces and flipped normals.
With xview i can highlight what needs to be flipped with face orientation, but I can't transfer the highlighted faces to a sub selection.
Edited by raymarcher
Bonjour postite, I should have explained it better. I want to add a turbosmooth or a simple smooth modifier with it, for that you need welding, and for welding you need to have an uniform face orientation.
greetings from belgium
Here is my detailed workflow:
  1. Do a "Create shape" in poly edit mode with all edges selected sothat you have a spline network.
  2. Delete the old mesh and export the spline network in *.dwg
  3. Open Mensura/ New project
  4. Link a dwg (the one just created before)
  5. Module/ Land (new window opens)
  6. Open the layer manager and with the green arrow import all layers from your dwg to this project
  7. Land/ Create land (or something like that) (popup appears)
  8. Click "OK" (popup closes)
  9. Right-click in the scene (contextual menu appears) click "All"
  10. Then push "Enter" on your keyboard and it's done
  11. File/ Export to dwg
  12. Import in max
