alywhosane Posted November 24, 2010 Share Posted November 24, 2010 Hi guys, I am havng a problem with vray i am running windows 7 and max2009, vray installs perfectly without any errors, i can select my renderer as vray but the problem is i dont see the vray sun/ies lights/ vray cameras have disappeared no vray plane noting..is anyone facing the same problem i am running win7 32bit. Please advise Thanks. Link to comment Share on other sites More sharing options...
Logitek Posted November 24, 2010 Share Posted November 24, 2010 Hi Aly, Are you sure you don't have the lights checked in the display/Hide by catergory tab? If not that... I don't know good luck! Link to comment Share on other sites More sharing options...
alywhosane Posted November 24, 2010 Author Share Posted November 24, 2010 Hi Aly, Are you sure you don't have the lights checked in the display/Hide by catergory tab? If not that... I don't know good luck! Well thanks for the reply logi but i found out wat the problem was..its due to the rights issue in win7 i ran max as Administrator and it worked fine..i wonder how we can over come that problem. Thanks again Link to comment Share on other sites More sharing options...
