Sketchrender Posted November 24, 2010 Share Posted November 24, 2010 Leaf is the way it has been described, as in a leaf blowing in the wind............... Anyway I have having trouble modeling this roof correctly. I can fudge it with FFD's ect, but it is being used as a template for the engineer to design from also. So can anybody tell me a correct and accurate way of using the section lines I have been given to swip or mesh this correctly. Thank you phil Link to comment Share on other sites More sharing options...
Cyberstyle Posted November 25, 2010 Share Posted November 25, 2010 I'd start with an editable spline using the bezier curves to get your shape, add a surface modifier, and then depending on your final needs add either an Edit Patch modifier (to tweek further) or Edit Poly modifier. Link to comment Share on other sites More sharing options...
Frosty Posted November 25, 2010 Share Posted November 25, 2010 I think FormZ could do this pretty easy. Likely Rhino too. Link to comment Share on other sites More sharing options...
