topographic data
Alyosha
Hey,
i got a dwg from client where they have included a topographical map of the area in terms of splines
I wonder what would be the best approach to convert this into a polygon mesh, i attempted converting into NURBS and continuing from there but (probably due to insane number of vertices ont he splines) it just froze max a couple of times.
Is there a way to optimize this? Or any other way to approach this problem without having to model mesh manually?
If the splines are at their correct heights then make sure they are all attached as a single object and create a terrain object. You can find it under Create>Compound. If the drawing is flat then you will have to move them manually to the correct heights before performing this step.
If the number of vertices in the splines is causing a problem then add a Normalize Spline modifier first to control the number of verts.
