Wierd snap problem
Alyosha
Out of the blue Max decided it will perform move command erratically, as if it was affected by snapping, which it is not!!!!
If i want to move for example a box it will seem as if it's trying to locate a snap point or smtn and will resist, only to then jump by a random number of units into the given direction, impossible to work!!!!
What has happened??????
Snapping is off, snapping options pretty much didnt yield anything interesting either.
Tried creating a brand new file and it does the same!!!!!!!
Please help, it's impossible to work like this!
Argh there's moments i wish i had stayed with c4d........
Edited by Alyosha
kinda fixed it....when i resized the entire scene by some 5000% it threw it waaaaaaaaaaay off the zero coordinates, aparently this is what was causing problems...and when i merged into new file ofc the coords stayed so nothing changed...
setting it back near the 0,0,0 worked like a charm
it's funny how you sometimes have to post a problem on the forums i think it helps with thinking:-)
