HELP 3dmax 5.1 display
Gabriella_A
Hallo...
I need help for a display problem in max 5.1... this morning I "lose" the red square that is between the x and y axis... the one that glows if i choose to restict one of the axis...
How can I restore It without re-installing max?
Another question... I don't know how and why :) but my display since two weeks shows all the surfaces and the mesches with a triangulate division (what a horrible way of saying...) .. even if I have a plane with only four edges I see one more diagonal edge... that is not a real edge..
I know that is only a display option, but how I can go back to the previous version?
Thanks in advance,
Gabriella
to fix your gizmo problem: go to customize>preferences>gizmo, it must be turned on.
have you recently switched to opengl? if so the strips that you see may be visualized by default. try checking your display driver configuration customize>prefereces>viewport>configure driver, use triangle strips must be unchecked.
Thank you so much Massimiliano :))
You solved the problems...
I changed the gizmo options by mistake while I was trying to solve the problem of the triangle strips :))
I could never imagine that the problem was in the driver configuration.
Thanks again,
Gabriella
P.S.
We work in the same city!
