paneli Posted December 6, 2010 Share Posted December 6, 2010 (edited) Imagine the situation. I save my render settings into a render preset. Saving my work, closing 3D MAX. After awhile, opening 3D MAX once again, loading my scene and picking up the same render preset. The issue - as soon as I load another preset (or reload the same) the Vray Sky returns to default setting (in other words, loses connection with Sun) and I have to pull the configured Vray Sky from the Material Editor (Instance or Copy) again to the GI Environment. It wouldn't be so terrible if I had only 1 or 2 viewpoints. But I have 6. It's kind of annoying resetting the GI Environment every time I change the render preset. The problem appears in both machines. One runs Windows XP SP3 with 3D Max 8 & Vray 1.5RC3 Second runs Windows 7 Ultimate 64x 3D Max 2009 & Vray 1.5SP4a Help? P.S What presets are used for if not quick loading render setting to a current view or scene? Edit: I tried the same thing with Windows 7 Ultimate 64x + 3D Max 2011 & Vray 1.5SP5. Anyway to get over this? Edited December 7, 2010 by Panibor Link to comment Share on other sites More sharing options...
sanmb Posted December 8, 2010 Share Posted December 8, 2010 Try this, Select sky from Rendering,Environment,environment map,drag from the same place to v-ray environment settings in v-ray settings and use v-ray sun. Link to comment Share on other sites More sharing options...
