thorsten hartmann Posted December 8, 2010 Share Posted December 8, 2010 Hi Guys, The new Hot Fix 4 is reased and for mental ray some bugs eliminate. - Satellite Rendering (DBR): The issue with the satellite rendering license which was caused by the previous Hot Fix has been resolved. - When using mental ray proxies and setting mental ray to use BSP2 when rendering to a sequence, some of the memory was not released . This has been fixed. - When setting mental ray to use BSP2 in 64-bit versions of 3ds Max, speckled artifacts could appear when rendering; these artifacts no longer occur. http://area.autodesk.com/blogs/shane/hotfix_4_3ds_max_2011_3ds_max_design_2011 mfg hot chip Link to comment Share on other sites More sharing options...
