Vray Sky + Vray PhyCamera + Environment BITMAP issue
paneli
When I configure Vray Sky (Linked with Vray Sun), I pull the Sky into GI environment as Skylight.
Also Vray PhyCamera F/ 8.0, Shutter 180, ISO 100.
A Vray Sky for Reflection/Refraction in GI Environment.
The same Vray Sky for background Environment
It works well.
But,
when I replace the Vray Sky with a Bitmap (only in background Environment and Reflection/Refratcion) the sky turn black, although its still configured in GI Environment (skylight) override.
Anything to do with it? (I want to place a bitmap reflection in the windows, but as soon as I try that... you see)
LWF is correct, I guess.
SOS
problem is the exposure control in the physical camera. A bitmap background isn't as bright as the vraysky. Turn off "affect background" in the vray color mapping rollout.
Oh, I get it.
But if I turn the exposure down, I see the sky perfectly but everything is burned.
If I turn off "affect background" in the color mapping rollout I see the sky, but the Reflection/Refraction is actually what I need.
I managed to put an HDRI instead (I had to incrase the multi to 70 - is that correct?)
and it worked fine. But still - what about bitmaps?
Edited by Panibor
  • 6 months later...
