danb4026 Posted December 14, 2010 Share Posted December 14, 2010 I have a render that is 3200x1650. I need to expand the view as per client to extend the sides out about an inch each. Because I have already done so much photoshop work, I want to render this out and just plop it in as a base layer. Problem is, when I adjust the width, it doesnt just make the image wider, it also lessens its height. I don't want that! I just want to make it wider, while keeping everything else the same. Is there a way to do this without moving the camera and screwing up everything I have already done. Using Vray Cam. Thanks Link to comment Share on other sites More sharing options...
Stephen Thomas Posted December 14, 2010 Share Posted December 14, 2010 Search for a script called Overscan, does the job without you having to recalculate FOV etc. Link to comment Share on other sites More sharing options...
Camby1298 Posted December 14, 2010 Share Posted December 14, 2010 I would simply change your image size to the desired width (with keeping the same image aspect ratio) and do a region render; cropping out the extra top and bottom areas of the image while adding the extra left and right portions. Link to comment Share on other sites More sharing options...
danb4026 Posted December 14, 2010 Author Share Posted December 14, 2010 Stephen, do you know if it works with a vray camera? Camby, I wish what you suggested would work, but it simply changes the resolution not the actual canvas size. Link to comment Share on other sites More sharing options...
danb4026 Posted December 14, 2010 Author Share Posted December 14, 2010 Looks like overscan may work! I used it with a regular max camera, ran the script, and then converted that camera to a vray cam. Did exactly what I wanted....now rendering. Thanks! Will let you know if the rendering comes out as expected. Link to comment Share on other sites More sharing options...
danb4026 Posted December 16, 2010 Author Share Posted December 16, 2010 Worked like a charm. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted December 16, 2010 Share Posted December 16, 2010 Glad to hear it. It can be a real life-saver sometimes! Link to comment Share on other sites More sharing options...
