Missing DLL Dialog Box
Arkitec
When opening a file in Viz 4 (has only been opened on Viz4) a dialog box comes up with:
Missing DLLS : FileName: boolcntrl.dlc Class: Boolean Controller. THis does not happen in the startup file when opening Viz
Is there a way to remove this? Is there a function in Viz like AutoCAD that I can "Wblock" the file out?
I have tried merging the file into another drawing, but the missing driver box pops up too.
Thanks for any help.
Arkitec
I don't know if you how you can remove that missing DLL pop-up, but was the file created in another program where it used that particular boolean controller that your Viz 4 program doesn't have? I found that downloading a model created from another program but can be imported or opened in Viz4 sometimes have plug-ins or something Viz doesn't have installed that opens with errors. I don't know the way around it. It would be nice to know though...
Well the file was imported into Viz by 3ds created in FormZ; however, I havent had any problems doing this....ever.....Since the import into Viz, I havent had any problems.
I tried to "repair" viz from the install disk and that didnt help. I havent imported anything since this box came up either.....
Any thoughts on "wblocking" the file out....is there a script out there or something that you know of?
Thanks for the speeding response.
Arkitec
abicalho,
I did a search on my harddrive and did see it in my max5 directory. However, I never opened the file in max...So, how do I substitute the driver....? If I remove max 5 from my system should that fix it?
Thank you for any help...
Arkitec
