Tip: Slate/SME: Replace all outputs from one node to another with a single drop...
PiXeL_MoNKeY
I found this little gem the other day. Basically if you have 2 nodes and you want to replace all outputs from one to the other you simply drag the output socket from one node, to the one with the existing outputs. Once dropped the outputs will all be moved from one node to the other. This works for all compatible node types (map to map, material to material, controller to controller, etc) and will give you a bright green output socket if supported. See the attached image for more descriptive view of the process.
-Eric
