djoshi Posted December 20, 2010 Share Posted December 20, 2010 I was working in 32 bit xp, max 2009 32 bit, i7 860, 4 GB RAM, Vray - But file could not render & keep crashing while render.. Memory error appears... So I installed 64 bit xp in another drive, now it renders fine but it crashes while working on file..Error comes is "Error occurred..." Error comes even I switch between files..?? What should I do:confused: seems 32 bit stable but could not render heavy scene.. And 64 bit can render but not stable..Pls. help me..stuck badly:confused: Link to comment Share on other sites More sharing options...
andrejcordeiro Posted December 20, 2010 Share Posted December 20, 2010 I was working in 32 bit xp, max 2009 32 bit, i7 860, 4 GB RAM, Vray - But file could not render & keep crashing while render.. Memory error appears... Hello there... How much memory you have in your computer? Link to comment Share on other sites More sharing options...
djoshi Posted December 20, 2010 Author Share Posted December 20, 2010 8 gb.. Link to comment Share on other sites More sharing options...
andrejcordeiro Posted December 20, 2010 Share Posted December 20, 2010 8 gb.. Well, maybe the problem is within the settings for the render itself....can you make a print screen of the settings you have....and a print screen of the error message. Link to comment Share on other sites More sharing options...
notamondayfan Posted December 20, 2010 Share Posted December 20, 2010 it could be anything from bad geometry, bad maps, modifiers, plugins, scrips, etc. Does it happen with all files, or just one in particular? Link to comment Share on other sites More sharing options...
djoshi Posted December 20, 2010 Author Share Posted December 20, 2010 notamondayfan - with that one file only & that file opens well on 32 bit..( But not usefull as it requires more memory to render which is not possible in 32 bit xp). I also think some bad geometry causing this but how can we come to know that which object is doing this as there are so many object in scene. andrejcordeiro - Error is something like " Error occurred application will close now click save to save file or cancel..." with red cross.. Link to comment Share on other sites More sharing options...
Paul Twyman Posted December 20, 2010 Share Posted December 20, 2010 Ok, massive stab in the dark but do you have the HSDS modifier on anything? I know that this causes issues in 64bit. Failing that you wanna try merging things into a clean scene. Use a half then half again method for merging until you find the culprit. i.e. Merge half the scene, if it is ok you know the offending object is in the other half or vice versa. Then keep doing this with the problem half until you find the issue. Hope this helps Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
notamondayfan Posted December 20, 2010 Share Posted December 20, 2010 Try these steps - Merge everything into a new scene. Check all materials are using the ones your renderer supports. Ungroup everything. Go though each object and collapse the stacks where possible. Delete any unused objects, shapes, lights, etc. That usually works for me with dodgy files. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted December 20, 2010 Share Posted December 20, 2010 My favorite first step is to delete the 3dsmax.ini files, and let it create a new one. Though this usually fixes crashes on start up, not necessarily switching between projects, but it couldn't hurt anyway. Link to comment Share on other sites More sharing options...
djoshi Posted December 21, 2010 Author Share Posted December 21, 2010 Thanks guys.. Now it is working fine..I was sure that, things that I have modeled & done would not have a problem..so I have started deleting objects which are merged from library..ultimately got that object:mad:..fwhooh.. Feeling relieved now..... Some times situation makes you crazy..when you are working in tight deadlines..& You are seeing yourself in wasting time in useless things..& not doing what you are paid for..anyways..this is a part of our industry... Link to comment Share on other sites More sharing options...
