Superkames Posted December 27, 2010 Share Posted December 27, 2010 //Sorry for my English . I need your help to known ‘How’s your VGA card performamce with 3dsmax 2011 viewport’ . Hi everyone . I have a file to test here : http://www.mediafire.com/?i3apim2mhl8k3qh +Unzip + Open the file with max 2010 or 2011 +Press ‘C’ to turn to camera 01. +press play animation and shot the highest Fps you get with Rrintscreen key on your keyboard +Turn to Wireframe , hiddenline , smooth+highlight . My PC : -AMD X6 1055T@4ghz (Higher clock ~ higher fps ,Intel CPU will give you higher Fps with same clock) -ATI HD 4850@firepro V8700 (So that I could use the performance driver) -2*2gb DDR2 800@1040 -Dell 2209WA (resolution 1680*1050 ).3dsmax take full screen. -And others hardware.......... And the result below : AMD 1055T@4ghz + HD4850@V8700 firepro ( AMD Performance plugin ) : Hidden line : 9.379 fps Smooth + Highlights : 15.255 fps Wireframe : 18.188 fps AMD 1055T@4ghz + HD4850 ( Direct X9) Hidden line : 7.56 fps Smooth + Highlights : 12.47 fps Wireframe : 13.85 fps Thanks for your help . Another thing:D . Please shot a screen like this to show how many percent that your card loading . Link to comment Share on other sites More sharing options...
Superkames Posted January 9, 2011 Author Share Posted January 9, 2011 Default test: -Max2011 + Win 7 64bit -AMD X6 1055T default 2.8ghz (no turbo core) . -ATI HD 4850 -2*2gb DDR2 800 -Dell 2209WA (resolution 1680*1050 ).3dsmax take full screen. And the result below (DirectX9) : Hidden line : 6.05 fps Smooth + Highlights : 9.91 fps Wireframe : 11.15 fps Link to comment Share on other sites More sharing options...
Superkames Posted January 9, 2011 Author Share Posted January 9, 2011 Another benchmark @ 3.5 ghz ( I usually use my PC at this clock) Link to comment Share on other sites More sharing options...
