fatNjazzy Posted July 18, 2004 Share Posted July 18, 2004 hi there... can i create a sections and elevations like in ADT (autodesk architectural desktop) in order to show 2 differenr floors? thank u all. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted July 18, 2004 Share Posted July 18, 2004 Well, Max isn't exactly made for sections and elevations like the ones you create using ADT... But, you can either use the camera clipping plane to virtually "cut" the unwanted floor away for rendering (with some post-porduction in PS) or slice it and actually set them apart. But, if you already use ADT, I suggest you take these sections/elevations from it and import them into Max. Link to comment Share on other sites More sharing options...
STRAT Posted July 18, 2004 Share Posted July 18, 2004 slice is the daddy!!! Link to comment Share on other sites More sharing options...
fatNjazzy Posted July 19, 2004 Author Share Posted July 19, 2004 thank you, i will try that. Link to comment Share on other sites More sharing options...
mhinks Posted July 19, 2004 Share Posted July 19, 2004 Without sounding stupid, but it is a monday and my head is feeling heavy, ive not heard of the slice tool, unless your refering to the slice in edit mesh! now my brain kicks in. if not, where would i find it? Link to comment Share on other sites More sharing options...
STRAT Posted July 19, 2004 Share Posted July 19, 2004 under the modifiers list it's a parametric modifier Link to comment Share on other sites More sharing options...
mhinks Posted July 19, 2004 Share Posted July 19, 2004 Got it! very nice tool. sometimes i think there are probably so many tools undiscovered in max! Link to comment Share on other sites More sharing options...
fatNjazzy Posted July 20, 2004 Author Share Posted July 20, 2004 i can only slice one object with this modefier, how can i slice the hole project? thank u very much. Link to comment Share on other sites More sharing options...
STRAT Posted July 21, 2004 Share Posted July 21, 2004 just for the slicing job attatch all objects together into one object. Link to comment Share on other sites More sharing options...
Chad Warner Posted July 21, 2004 Share Posted July 21, 2004 Or do Like Rick says and use the clipping plane with the camera, which will require cleanup with photoshop. -Chad Link to comment Share on other sites More sharing options...
