ssstrutz Posted January 12, 2011 Share Posted January 12, 2011 Hello all, I have recently been working on a kitchen rendering and I typically create the model in Autocad 2011(saved down) and file link to max 2010. Any object with a curve is coming in to max not looking like an arch. It is not smooth as you can see in the picture included. Does anyone know how to make this a smooth arch when it is inserted into 3Ds Max? I have not had this problem before. Thanks!!!! Link to comment Share on other sites More sharing options...
njoco2 Posted January 12, 2011 Share Posted January 12, 2011 Scott, try increasing the curve steps and lower the Max surface deviation for 3D solids in the import dialog. Link to comment Share on other sites More sharing options...
ssstrutz Posted January 13, 2011 Author Share Posted January 13, 2011 Thanks for the reply. I bumped up the curve steps to 30 and decreased the deviation to .25" for 1" however the curves are still coming in as straight lines. Link to comment Share on other sites More sharing options...
kippu Posted January 13, 2011 Share Posted January 13, 2011 increase it further , till max curve steps and decrease the deviation also Link to comment Share on other sites More sharing options...
ssstrutz Posted January 15, 2011 Author Share Posted January 15, 2011 I was searching through some other posts and found people with the same issue a while back. They fixed it by importing as a Legacy dwg file. I tried it and it did work, however the file is not linked. It makes it a little bit tougher when you make changes, but I needed to get the project out the door and couldn't wait to keep trying the linking. I had a very detailed cad drawing that would take about 8 minutes to load though file link. Thanks for the help, I will mess around to see if there is a better way to make it work for the next job. Link to comment Share on other sites More sharing options...
