Renato1 Posted July 19, 2004 Share Posted July 19, 2004 I would like to know if it is possible to render out elevations at a particular scale. Is there a way that you can setup the camera. Thanks Renato Link to comment Share on other sites More sharing options...
STRAT Posted July 19, 2004 Share Posted July 19, 2004 just put in a small model of a scale line before rendering. Link to comment Share on other sites More sharing options...
rivoli Posted July 19, 2004 Share Posted July 19, 2004 Is there a way that you can setup the camera. as long as i know there's no such a thing, but you can easily rescale your elevations in PS. Link to comment Share on other sites More sharing options...
Bhanu Posted July 20, 2004 Share Posted July 20, 2004 just put in a small model of a scale line before rendering. This works efficiently , once scale line in available in PS you can work with Image to get to exact scale. Link to comment Share on other sites More sharing options...
Chris Potts Posted July 20, 2004 Share Posted July 20, 2004 I have done it before....It quite simple...If you using Max/Viz and CAD Try do it follow step: MAX/VIZ 1) Scale doesnt matter, Just render output picture on elevation with high reslution as you can. and save it in Tiff File (dont forgot check alpha channel on). CAD 1) Plot render output on tiff file with excatly scale on paper size. Then finally, on Photoshop.... 1) Open up CAD render file picture and you will see there have outline elevation layout that is excatly scale....Do not change scale em. 2) Click add on 'Create a new layer' and put it order layout to background. And CAD layout turn into 'Multiply' layer that will do see thru with other layer 3) Open Max/Viz's render file picture and Click 'Select' under tool and click Load selection. You see there have alpha channel there and click 'ok' then drag em into CAD layer (Middle layer). And then scale Max's picture match into CAD outline... 4)When you done it excatly scale match and either delete CAD layer or keep it or rub out some area black line ie windows.... I hope this good enough help you what you look for.. Link to comment Share on other sites More sharing options...
Renato1 Posted July 20, 2004 Author Share Posted July 20, 2004 Thanks, but awhile ago i read some were that you can set the scale using an orthographic Projection Camera. The scale was determined by the distance of the camera target to the Camera. The further away the smaller the scale. It had nothing to do with the position of the camera in relation to the model. It was something like that. I just though some one else had seen it too and could remember. The Photoshop way works, no problems but the less things you have to change after rendering the better. Thanks Renato Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted July 20, 2004 Share Posted July 20, 2004 i would like to read this if you can find it. do you have to print directly from max for this to work? ....but like everyone said. photoshop. Link to comment Share on other sites More sharing options...
And0 Posted March 1, 2010 Share Posted March 1, 2010 There IS such thing for a couple of months it is called Amera S2DIO google it coz i don't have more that 10 posts Link to comment Share on other sites More sharing options...
KIT Posted March 1, 2010 Share Posted March 1, 2010 http://www.amera-s2dio.com/ Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted March 1, 2010 Share Posted March 1, 2010 I like to do my scaling in AutoCAD. M'be it's just a personal pref thing. Link to comment Share on other sites More sharing options...
And0 Posted March 1, 2010 Share Posted March 1, 2010 But how are you able to know how big to render... It is either time consuming to render larger or u just render less than you want and loose quality when scaling up... Either way it is a pain in the arse for me Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted March 2, 2010 Share Posted March 2, 2010 The time isn't that much of a hit for me so I just render big. And more often than not my work ends up getting used bigger than I was told. Last job I thank my lucky stars that I never saw the huge posters they put up in the lobby. Cringe. So anyway, since I can afford the time I like to have something extra big kicking around in case the need comes up at an inconvenient time. And... I don't get much call for it. Usually what I'm scaling in ACAD is scans and Google Earth and stuff. Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted March 2, 2010 Share Posted March 2, 2010 Amera looks like it might be nice to have kicking around. Next time I've got twenty bucks... Link to comment Share on other sites More sharing options...
andstef Posted March 2, 2010 Share Posted March 2, 2010 It isn't worth the money. (amera) I wouldn't use it even if it was for free (or maybe then). All you have to do is calculate the scale (i.e. if you want 1:100 than 1m equals 1cm on paper, and 1cm at 300 dpi is about 118 pixels (118.11023622047244094488188976378 to be more exact) ). I don't know even one case where I didn't have to bring the rendered image in photoshop, or autocad to scale and add various things like scale, date, name etc. so why bother getting it at the exact scale when you render. It really is not that complicated. And resizing images by 10% will not affect their quality (at least not visible to the human eye) It's more difficult with metric units because as I showed above 1cm at 300 dpi is not an integer number of pixels, but if you work with imperial units than it is really easy 1inch=300pixels for 300dpi regards Link to comment Share on other sites More sharing options...
