akryll Posted January 14, 2011 Share Posted January 14, 2011 So I'm looking at having someone build me a computer, and I was hoping to utilize as much of my old computer as possible. My biggest thing is the graphics card. I bought my current computer a few years ago and it has a NVIDIA Quadro FX4600 in it. Now when I bought the computer it was a very powerful card, not sure that is the case any more. The main reason I would like to build a new computer is to get into a 64 bit system with more ram. Any thoughts on this graphics card? Or how much a good one costs? Thanks Link to comment Share on other sites More sharing options...
Slinger Posted January 17, 2011 Share Posted January 17, 2011 QuadroFX4600 is old tech. I would not use it in the new build. What do use your system for? Link to comment Share on other sites More sharing options...
akryll Posted January 18, 2011 Author Share Posted January 18, 2011 Thanks Slinger- I'm starting to get into 3DS Max with Mental ray. I just purchased the software and have had a few crashes. I design homes and am trying to get into doing some still renderings to start off with. I use Autocad Architecture 2011. I have also had some blue screen errors while using ACA, so I think it is about time to get up to date with a more powerful machine. I just don't neccesarily want to pay a ton of money to buy one, which is why I'm looking at having someone build it for me. Link to comment Share on other sites More sharing options...
AJLynn Posted January 18, 2011 Share Posted January 18, 2011 The RAM and 64-bit issue is going to be a lot more important to you than the video card issue. If you're in 32-bit and doing ADT models to Max (which can run up the polygon count quite high) you could easily run into a whole mess of problems due to overrunning your app's memory allocation. As a stopgap, until you can get the computer situation figured out, try modifying your memory map in boot.ini (Google the procedure). Instead of the commonly used /3GB switch, which can cause nVidia driver problems by not leaving enough memory for the system, try /USERVA=2700 (and decrease the number if any drivers fail to load). Link to comment Share on other sites More sharing options...
Slinger Posted January 20, 2011 Share Posted January 20, 2011 Andrew Kryll, I would go with the midrange Build Andrew Lynn put together in his January write up: http://forums.cgarchitect.com/63958-new-intel-sandy-bridge-cpu-workstations.html Solid build for $1600. Link to comment Share on other sites More sharing options...
