Tim Saunders Posted January 18, 2011 Share Posted January 18, 2011 So, I have struggled to figure out the best way to run distributed rendering without having missing maps. There are just WAY too many models I have created and/or saved over the years on the network that do not have their bitmap paths updated. I just need to configure my external user file paths for the key directories. The problem is, the license has expired on a few of my render nodes. Is there an ini file or something I can copy and paste from a box that has the file paths configured to the other boxes? OR, any other ideas? Link to comment Share on other sites More sharing options...
Tim Saunders Posted January 19, 2011 Author Share Posted January 19, 2011 bummer. no ideas? Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted January 20, 2011 Share Posted January 20, 2011 (edited) I would try something like this, though I haven't actually done it before... Add an external path pointing towards your network, and tell it search subpaths. Save the mxp path file, and then copy it to the individual machines. Hopefully that path file will load when the render node launches, and it will search the path and locate the maps. Not sure if it will work, but that is where I would start. Edited January 20, 2011 by Crazy Homeless Guy Link to comment Share on other sites More sharing options...
John Pruden Posted January 24, 2011 Share Posted January 24, 2011 Use UNC paths for ALL your textures. You can use the Asset Tracker to set new paths for images that max has found, and for images max can't find use Collin Senner's "Relink Bitmaps" script. It's a life saver! Link to comment Share on other sites More sharing options...
