ltravisjr Posted July 21, 2004 Share Posted July 21, 2004 I just discovered the Desktop Radiance progam and it looks intriguin as it runs inside AutoCAD. However, the latest release of it says it will work within AutoCAD 2000 but there may be problems with later AutoCAD's. Since I am an AutoCAD 2005 user, can anyone tell me for sure if Desktop Radiance would work in it? If not, what is the cause of incompatiblity - the code itself or something more simple like a pathing issue? It would be a great program for me to try if I could run it in my Acad. Thanks! LT Link to comment Share on other sites More sharing options...
3dp Posted July 21, 2004 Share Posted July 21, 2004 i had it running in adt 3.3 in a office i worked at a couple of years back however it was slow (though good for certain work) i'd be intrested tp find a little more about the recent radience port to max to see if it more user friendly which was the autocad problem (then again i never had to use the unix version which is all code input yikes) Link to comment Share on other sites More sharing options...
