Neblin Posted January 26, 2011 Share Posted January 26, 2011 Hi guys! New here and already having problems haha! Hopefully you can help me out. I have to render this building, the courtyard in particular (as shown in the camera view). I'd like to have it as though sunlight went through the holes present in the façade, producing clear, strong shadows... however, whenever I render the scene in Vray, I get a black render window I've tried the default scanline renderer and mentalray, and both show some results (although not what I'm looking for, at least it's not black!) I've also tried making the lights cast vray shadows, used vray materials... nothing. BTW I'm using vray 1,50 sp4 and 3dsmax 2010. Any help is more than welcome! Here's the link to my .max file: http://www.megaupload.com/?d=TDQ3ZIVT Cheers, I'm really desperate! Neblin Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted January 26, 2011 Share Posted January 26, 2011 File is unavailable... Link to comment Share on other sites More sharing options...
Neblin Posted January 26, 2011 Author Share Posted January 26, 2011 Should work now Link to comment Share on other sites More sharing options...
maciejwypych Posted January 26, 2011 Share Posted January 26, 2011 Hi guys! New here and already having problems haha! Hopefully you can help me out. I have to render this building, the courtyard in particular (as shown in the camera view). I'd like to have it as though sunlight went through the holes present in the façade, producing clear, strong shadows... however, whenever I render the scene in Vray, I get a black render window I've tried the default scanline renderer and mentalray, and both show some results (although not what I'm looking for, at least it's not black!) I've also tried making the lights cast vray shadows, used vray materials... nothing. BTW I'm using vray 1,50 sp4 and 3dsmax 2010. Any help is more than welcome! Here's the link to my .max file: http://www.megaupload.com/?d=TDQ3ZIVT Cheers, I'm really desperate! Neblin 1. Move your camera out of a wall. 2. Remove the lights and replace them with vray sun, or at least adjust the angle, 3. Use vray physical camera and no exposure control 4. Turn GI ON [ATTACH=CONFIG]41040[/ATTACH] Hope that helps Link to comment Share on other sites More sharing options...
Neblin Posted January 26, 2011 Author Share Posted January 26, 2011 Thanks very much for your reply and effort I'm trying your suggestions right now. However, I'm looking for an image with stronger, more defined shadows... the kind that appear when sun shines through a window, like this: http://www.jupiterimages.com/Image/royaltyFree/76808304 Still messing around with vray and lights, but not any results yet... Any more suggestions? Cheers! Neblin Link to comment Share on other sites More sharing options...
erickdt Posted January 26, 2011 Share Posted January 26, 2011 If you're using a VRay physical camera you'll want to check your camera's exposure and shutterspeed settings. It could be that your F number is too high resulting in an underexposed image. E Link to comment Share on other sites More sharing options...
maciejwypych Posted January 26, 2011 Share Posted January 26, 2011 Thanks very much for your reply and effort I'm trying your suggestions right now. However, I'm looking for an image with stronger, more defined shadows... the kind that appear when sun shines through a window, like this: http://www.jupiterimages.com/Image/royaltyFree/76808304 Still messing around with vray and lights, but not any results yet... Any more suggestions? Cheers! Neblin If you want to have a sharper light/shadows, change the shadow bias in vray sun to 100 Link to comment Share on other sites More sharing options...
Neblin Posted January 26, 2011 Author Share Posted January 26, 2011 OK guys, trying out all your suggestions right now! Will let you know asap if it works! Cheers! Link to comment Share on other sites More sharing options...
Neblin Posted January 26, 2011 Author Share Posted January 26, 2011 Well, maciejwypych did what you told me and this is what came out,[ATTACH=CONFIG]41041[/ATTACH] clearly not what I was going for So there's something I'm doing wrong, obviously. I'm almost 100% sure it's something to do with the light. Would it be asking too much if you could upload the .max file you did for the render you posted on your previous reply so I could see how you placed the lights? Thanks! Neblin Link to comment Share on other sites More sharing options...
Ismael Posted January 27, 2011 Share Posted January 27, 2011 (edited) Changed 3 direct lights for a Daylight System set to manual to move at same angle of 3 directs. Changed Sun to VraySun and accepted Vraysky map option. Moved VraySky from Max Environment to Vray GI Skylight override. Created a Vray material 128 gray and applied to all. Created Vray Physical camera somewhere were Cam 1 was and Enabled VFB . Arrived at camera F-stop=8, SS=10 and ISO=100. Also turned off the max Exposure control as suggested early. Maybe some of this helps… editt*** add one textured Edited January 27, 2011 by Ismael Add Textured model Link to comment Share on other sites More sharing options...
