kish Posted January 27, 2011 Share Posted January 27, 2011 hi every one.. i am doing walkthrough,in that i want to use real footage of that site in that 3d building,can any one help how to do that... Link to comment Share on other sites More sharing options...
Nic H Posted January 27, 2011 Share Posted January 27, 2011 yes you should track the footage and make a camera so you can match your model in properly. Link to comment Share on other sites More sharing options...
kish Posted January 27, 2011 Author Share Posted January 27, 2011 but how to track in max...do u have ant tutorial for that ...it will be very help ful to me...thx for ur reply.. Link to comment Share on other sites More sharing options...
Nic H Posted January 27, 2011 Share Posted January 27, 2011 you will need to use boujou or pftrack etc to track the footage and make a camera to import into max as far as i know you cannot do it inside max then again you could actually be talking about something completely different can you use an image sequence on a plane or something? Link to comment Share on other sites More sharing options...
hkbasravi Posted January 28, 2011 Share Posted January 28, 2011 There is a Motion Tracker feature inside 3ds Max. It's not as user friendly imho as PF Track. However, it is there, and there are tutorials for it. You can access it by going to the hammer icon in your modifier stack, and select Camera Tracker. Or if you use after effects, there's a tracking feature in AE that's the most user friendly one I've come across. The problem with that is that you cannot export AE Cameras in to max without this boomerlabs plugin called Max2AE. I haven't tried the plugin because I run a Mac OS, and its only for windows. Link to comment Share on other sites More sharing options...
kish Posted January 28, 2011 Author Share Posted January 28, 2011 thxs for ur reply both...thxs very much Link to comment Share on other sites More sharing options...
