enthewhite Posted February 3, 2011 Share Posted February 3, 2011 Hello, Would anybody happen to know a way to take a soft selection of vertices (i.e. from the volume select modifier) and apply a modifier to it to change either the material id of the connected faces or assign a vertex color to them? I can easily use the volume select modifier to select faces instead of vertices, but this doesn't give me a soft selection and I would like the material of the selected geometry to blend with the original material. I would just use vertex painting or make a custom UVW map but this needs to update as the model changes (hence the use of the volume select modifier) Hope that makes sense, I am nearing my wit's end tonight. Thanks for any tips, Ian Link to comment Share on other sites More sharing options...
