re vit Posted February 6, 2011 Share Posted February 6, 2011 Does anybody have a clue how put a procedural tile map in a concentric (radial\helix-like) way? Thank you in advance. R . Link to comment Share on other sites More sharing options...
Bruce Hart Posted February 7, 2011 Share Posted February 7, 2011 There are several ways to do this. If say you used the sweep modifier to extrude a rectangle along a helix, you will be able to check the generate mapping coordinates tickbox. You can then play with the tileing parameters in the tile material to acheive the mapping size you want. Lofting and spline mapping (UVWunwrap) also allows you to generate mapping along a path. If you are using a helix for the loft path you may need to apply a normailze spline modifier so the mapping appears not so jagged. Link to comment Share on other sites More sharing options...
re vit Posted February 7, 2011 Author Share Posted February 7, 2011 Thank you, Bruce! And what about mesh exported from sketchup\ACAD (I model exlusevely in SU) ? Any hints? Link to comment Share on other sites More sharing options...
