CORRENTES Posted February 6, 2011 Share Posted February 6, 2011 (edited) Hello guys, Need some help about a animation... The thing is, I have one clip composed by 250 frames (10 seconds). In After Effects I composed the frames at 25 fps (10 seconds), then i composed again at 25 fps but at 15 seconds. With twixtor I re-timed so it fills the 15 seconds. And added some motion blur. Now the problem, the clip with 25fps have some stuttering that is really annoying. If i use everything at 30fps i end with a clip of 15 seconds 30fps and silky smooth. My problem is how I can achieve a 25 fps silky smooth like Alex Roman stuff ? Edited February 6, 2011 by CORRENTES grammar Link to comment Share on other sites More sharing options...
Fooch Posted February 17, 2011 Share Posted February 17, 2011 Essentially After Effects is doubling up some frames to fit it at 15secs = 375 frames. (read about pull down. That might help you a little) Twixtor should work. If it doesnt , here's the low tech version TRY THIS: Try time remapping + frame blending it. It might work this way. If thats a major issue, sometimes it might be easier to re-render at the perfect time. 15 secs instead of recreating frames. Link to comment Share on other sites More sharing options...
