How to approach this?
Dave Buckley
Right
So it turns out I didn't realise quite how much I relied on Revit for architectural modeling. Now I don't have it :( I'm using Max for everything (or trying to learn how to again).
I've modelled the basic architecture of a building based on some images grabbed from ArchDaily just to build up my portfolio.
It didn't take too long but I can't help thing there must have been an easier way.
I've attached the images i'm working with and wondering how you'd approach it?
I ended up tracing the out line with splines and ended up with one piece of wall which I extruded, then poly modelled the rest.
I'm not sure though if it would have been easier making separate splines for different walls etc due to the double heights and varying wall thicknesses. Would I have been better leaving gaps in between wall splines where there are windows and then filling the blanks? I initially covered the gaps and then subtracted using slices and bridges to create openings? I seemed to do a look of 'Create Polygon too to keep it clean.
Anyway interested to hear your thoughts.
trace image in CAD
leave blank where windows and doors but close spline for all "wall parts"
bring in
convert to poly
extrude
select blanks polygons
slice at openings heights
bridge
make doors & windows
make ceiling & floor
furnish [can be time consuming]
light
materials
light
materials
render
go for beer :)
done
basic unfurnished model of that first picture should be done in under [max.] 2 hours
thanks for letting me know :) makes me feel better.
if I was just doing the exterior I wouldn't care but i need to think about both in and out etc.
just practising different methods.
i know it doesn't really matter as long as the end result looks correct but I like to keep as clean as possible.
i guess I can always detach later on for different materials etc
one question I do have though is with regards the window to the right of the kitchen, there are no pictures in the collection that clearly depict it and I don't have plans or details.
does anyone with any construction experience know how this window is working. Just on a count of modeling the frame?
can anyone point me in the direction of some diagrams for this type of window?
