deathevor Posted February 12, 2011 Share Posted February 12, 2011 Hi, I have such problem. Here's the example of the scene: By deathevor at 2011-02-10 I've used mr Sky Portal and rendered it with Mental Ray (Final Gather and GI ON). I also rendered Diffuse and Shadow pass, and everything worked ok. But, my aim is to render the same image with Matte/Shadow/Reflection Material on the ground plane. (For later compositing on to Video footage) So that what I've get. 1) Rendered picture - Ok By deathevor at 2011-02-10 Here's an Alpha channel for it. And first problem is that it doesn't have the area with reflected light in the front of the cube. By deathevor at 2011-02-10 2) Shadow Pass - Fail (just empty RGB and empty Alpha channels) By deathevor at 2011-02-10 Link to comment Share on other sites More sharing options...
deathevor Posted February 12, 2011 Author Share Posted February 12, 2011 3) Diffuse Pass - Fail (Some glitches + Shadow pass) By deathevor at 2011-02-10 And basically the alpha channel for Diffuse pass is the same as for Render By deathevor at 2011-02-10. So really I can't make it work at all. I've tried with different lights (Phonometric, Daylight, Standard lights), with FG and GI off, different materials(Standart and Mental Ray) . But still the same result, Diffuse contains shadow pass and Shadow pass sometimes has some information, but mostly it's glitches. Does anyone can suggest the way to make it work? I also want to ask about this - Which Pass should I use to render this part separately from others? (I will remind that on Renderer and Diffuse pass the alpha didn't contain this area) By deathevor at 2011-02-10 Thanks Link to comment Share on other sites More sharing options...
JonRashid Posted February 12, 2011 Share Posted February 12, 2011 I don't know if this will help but I have been having weird problems with matte shadow planes. If i put a duplicate object just below my ground plane with a normal material on it things seem to sort themselves out. Link to comment Share on other sites More sharing options...
deathevor Posted February 12, 2011 Author Share Posted February 12, 2011 Hi, If you mean this, By deathevor at 2011-02-12 Doesn't work for me. And here's the shadow alpha channel- By deathevor at 2011-02-12 Link to comment Share on other sites More sharing options...
