Deetee Posted February 16, 2011 Share Posted February 16, 2011 Hello guys... as we all know if we wanted to display our texture as full resolution inside viewport display, we go for option below Enable Customize->Preferences->Viewport->Configure Drive->Match Bitmap Size as Closely as Possible, and restart Max. but my current problem is that whenever i checked on "match bitmap size as closely as possible" and restart, it just revert back to unchecked mode... why is it so??? i used to use this option for better bitmap display purpose, but why fail for this time? i used to use 3ds max 2010, and now in this new company, we use 3ds max design 2011. can it be the issue? this version buggy or something??? how can i fix it??? Link to comment Share on other sites More sharing options...
DavidR Posted February 16, 2011 Share Posted February 16, 2011 No, don't restart Max, just do everything up to that, then reload the map in mat editor. I don't know why Max doesn't keep the 'match bitmap" setting anymore -Max gets more broken with every release since 2009 is the only answer I can give you. Link to comment Share on other sites More sharing options...
Deetee Posted February 16, 2011 Author Share Posted February 16, 2011 uh... reloading maps in mat editor helps? i didnt know that... thanks for the information!!! im definitely gonna try it tomorrow when i get back into the office. yeah... sometimes i seriously dont understand what autodesk "updating" the version too... there are quite several stuff i seriously hate it about in 2011. snap tools in 2011 is totally **** up!!! back to ver 2010, splitting 3dsmax and 3dsmaxdesign is kind a joke too. Link to comment Share on other sites More sharing options...
Deetee Posted February 17, 2011 Author Share Posted February 17, 2011 No, don't restart Max, just do everything up to that, then reload the map in mat editor. I don't know why Max doesn't keep the 'match bitmap" setting anymore -Max gets more broken with every release since 2009 is the only answer I can give you. thanks a lot!!! this helps!!! Link to comment Share on other sites More sharing options...
