renato Posted July 23, 2004 Share Posted July 23, 2004 Hi: Is lightwave accurate for arch models?. I usually draw architectural floorplans in autocad, the I import this drawings into max, which gives me the perfect template, I just extrude my imported polylines to get a solid wall with the exact autocad measures. That seems to be hard in LW. Anybody has tried to work in Lightwave tis way?, any suggestions? thanx in advance Link to comment Share on other sites More sharing options...
ingemar Posted July 23, 2004 Share Posted July 23, 2004 I'm not doing it often but try saving out as dxf v.12 and open it in modeller. You can also give the polylines some height i AutoCad and export as 3ds and open that in modeller. Check this thread for a longer discussion: http://www.cgarchitect.com/vb/showthread.php?t=3727&page=1&pp=10 Link to comment Share on other sites More sharing options...
Jure Posted July 23, 2004 Share Posted July 23, 2004 I always export AutoCAD drawings as v12 .dxf and then import that into LW. Then I extrude those lines to get perfectly accurate model. It just need some cleaning up later because 2 point polys extrude into double sided polygons. Link to comment Share on other sites More sharing options...
renato Posted July 23, 2004 Author Share Posted July 23, 2004 Thanx guys, I've got the point. It could be useful to "clean" my autocad drawing first, leaving just the basic stuff I need to make an accurate model, maybe just the contours, then export this lines and adding details directly in LW Link to comment Share on other sites More sharing options...
Jure Posted July 27, 2004 Share Posted July 27, 2004 Yes exactly. Prepare everything you can in AutoCAD first, it will save you a lot of time later on... Link to comment Share on other sites More sharing options...
sonny Posted June 17, 2005 Share Posted June 17, 2005 try exporting the dwg. as illustrator file into modeller and no need to clean up double sided polys. I hope this would be of help. Link to comment Share on other sites More sharing options...
Limbus Posted June 17, 2005 Share Posted June 17, 2005 If you export as 3ds make sure to grab this plug: http://www.flay.com/GetDetail.cfm?ID=1394 It converts tris to quads. Florian Link to comment Share on other sites More sharing options...
MetaHumanitY Posted July 5, 2005 Share Posted July 5, 2005 It really depends on what You do. I usually loft everything from imported dxf lines without problems. Search Flay.com for Snap and align plugins and You´re halfway there. Lightwave can be used to model with high accuracy and numerical inputs. Link to comment Share on other sites More sharing options...
