blockyear Posted February 18, 2011 Share Posted February 18, 2011 Okay, yes, I'm new. Rhino + VRay. I'm bringing sunlight in through a transparent panel with objects on both far and near sides. I get shadows cast through the panel but cannot pick up shadows on the panel itself. So I want the panel to receive shadows as well as pass them through. I suspect that I'm needing a 2-sided material but am unclear how to set one up. Thanks! - Brian - Link to comment Share on other sites More sharing options...
Ismael Posted February 18, 2011 Share Posted February 18, 2011 Perhaps you could learn something about that material: http://www.peterguthrie.net/blog/2009/11/3d-tree-material-tutorial-leaves/ I placed a light and a small pole inside a box with a 2 sided material and could see the light and the shadow from the inside of the box. However, adding a light outside even stronger than the one inside the box, I could not get an object to cast a shadow on the topside of the box, however there is a shadow on top but is only visible from within the box! Link to comment Share on other sites More sharing options...
blockyear Posted March 3, 2011 Author Share Posted March 3, 2011 Thanks, I'll give that a shot. - B - Link to comment Share on other sites More sharing options...
