chunter3 Posted February 20, 2011 Share Posted February 20, 2011 Hi, I have been working on my model using vray mtl and then adding a texture to the diffuse slot...but id like to add another texture on top of the first one so that I can achieve a "dirtier" more natural look....my textures are too clean. i know that you can create sub materials, but is it possible to add another material to a vray mtl? or do i need to create a whole new material? Any help would be great...thanks Link to comment Share on other sites More sharing options...
sanmb Posted February 20, 2011 Share Posted February 20, 2011 You can add noise. play with noise option to get desired texture or make a new texture map. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted February 20, 2011 Share Posted February 20, 2011 There are a number of ways to do this.... Combining Multiple Materials VrayBlendMtl Composite Blend Shellac Combining Multiple Textures VrayCompTex Composite Gradient Ramp Another method some people use is to add a VrayDirt texture to a VrayExtraTex render element, and then composite the dirt/AO dirt in post. Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted February 23, 2011 Share Posted February 23, 2011 Another way that works in scanline and MR is to use a map with map slots on its subparts. For example, Noise is black and white, BUT you can put a map in each of those colors. Same for many maps. Link to comment Share on other sites More sharing options...
tommyjj Posted February 23, 2011 Share Posted February 23, 2011 use a Vray blend material, it's ideal for what you need Link to comment Share on other sites More sharing options...
