zhopudey Posted February 23, 2011 Share Posted February 23, 2011 Using wide angles on cameras creates a weird jelly wobble effect in animations. It is particularly noticeable in corners. Any way to avoid this? Sorry I can't explain the problem any better Link to comment Share on other sites More sharing options...
kippu Posted February 23, 2011 Share Posted February 23, 2011 dont use wide angles? Link to comment Share on other sites More sharing options...
BrianKitts Posted February 23, 2011 Share Posted February 23, 2011 dont use wide angles? +1 the benefit of an animated camera is that it can look around, you'll get more realism by not using a wide angle. Also don't use vertical correction. Link to comment Share on other sites More sharing options...
Nic H Posted February 23, 2011 Share Posted February 23, 2011 + 2 don't use wide lens w/ big pans in small spaces. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted February 23, 2011 Share Posted February 23, 2011 Can you post a short clip of your animation. It could be a separate problem other than the camera angle you are using. Link to comment Share on other sites More sharing options...
zhopudey Posted February 24, 2011 Author Share Posted February 24, 2011 Can't post any clips right now. I'll try with focal lengths and check. Link to comment Share on other sites More sharing options...
Jeff Mottle Posted February 24, 2011 Share Posted February 24, 2011 Might want to consider getting a few books on cinematography and studying up on how cuts and focal length are used in movies. Link to comment Share on other sites More sharing options...
Fooch Posted February 25, 2011 Share Posted February 25, 2011 Might want to consider getting a few books on cinematography and studying up on how cuts and focal length are used in movies. +1 aye aye. The whole archi wide angle shot is just overused dramatically... Link to comment Share on other sites More sharing options...
zhopudey Posted February 25, 2011 Author Share Posted February 25, 2011 Might want to consider getting a few books on cinematography and studying up on how cuts and focal length are used in movies. Good idea. Will do that. Link to comment Share on other sites More sharing options...
sanmb Posted February 27, 2011 Share Posted February 27, 2011 Can you post camera settings and path constraint settings? Please check if by mistake, Bank and allow upside down are on,makesure its off. This might help you. Link to comment Share on other sites More sharing options...
