randigi Posted July 25, 2004 Share Posted July 25, 2004 i just started to use vray and when i set all things i get to much blure on the flor tils . here are to images first 1 with simple sky light and 1 direct light. the second image with vray. anyone can help me with the render settings in vray so i can get better result? ill add the vray setiings too if somone can help me with the settings so i can get better results. Link to comment Share on other sites More sharing options...
randigi Posted July 25, 2004 Author Share Posted July 25, 2004 this is my setings if somone can help me get a better result Link to comment Share on other sites More sharing options...
kippu Posted July 26, 2004 Share Posted July 26, 2004 well it depends on what filtering you are using for the bitmaps in the textures try summed and even none for that matter on a more general note ....try posting in chaoticdimensions forum...very helpful ppl and faster replies Link to comment Share on other sites More sharing options...
jysngltndz Posted July 26, 2004 Share Posted July 26, 2004 randigi, i use vray for interiors you can check my works http://www.cgarchitect.com/gallery/galleryList.asp?searchName=6237&searchChecked=1 i havnt use it for exterior. by looking at your settings, for image sampler try using adaptive, for your bounce make it lesser, for the 1st bounce just keep it 1 and the 2nd around .6. maybe its your bounce that made all the blur. just try, and post your images after.... one thing i notice your using u are using vray 1.09.03r for max6 right? were did you get that? is it original or downloaded. ive been looking for that free full version, can you share with me your link if thats from the net? coz for now im stuck with max5 coz my i dnt have that full version of vray for max6.... Link to comment Share on other sites More sharing options...
jysngltndz Posted July 26, 2004 Share Posted July 26, 2004 hey mark,what do you mean bout the depth value? is that for the DOF? Link to comment Share on other sites More sharing options...
jysngltndz Posted July 26, 2004 Share Posted July 26, 2004 ok.. hmmh i never tweak that part of gi, i think im missing a lot.. Link to comment Share on other sites More sharing options...
randigi Posted July 26, 2004 Author Share Posted July 26, 2004 thanks all for the fast replys ill check it soon Link to comment Share on other sites More sharing options...
Christopher Nichols Posted July 27, 2004 Share Posted July 27, 2004 jysngltndz said: ok.. hmmh i never tweak that part of gi, i think im missing a lot.. Depth is the most basic part of GI... it means how many times the ray (light) bounces. It can be used for specular (reflections), for diffuse (what you call GI), or for transparency (refraction). It means how many times does a ray hit a surface before it stops. Link to comment Share on other sites More sharing options...
randigi Posted July 29, 2004 Author Share Posted July 29, 2004 here i the new image with some fixs Link to comment Share on other sites More sharing options...
Tim Nelson Posted July 29, 2004 Share Posted July 29, 2004 That looks great. How did you do your block material? Link to comment Share on other sites More sharing options...
randigi Posted July 29, 2004 Author Share Posted July 29, 2004 just a simple stone texture i created with a bump mape i did. Link to comment Share on other sites More sharing options...
Tim Nelson Posted July 29, 2004 Share Posted July 29, 2004 Any chance you could share the map with us? Also, did you use just a bump map, or displacement? Link to comment Share on other sites More sharing options...
randigi Posted July 30, 2004 Author Share Posted July 30, 2004 the ston is only with simple bump but i cant share it for now. the grass is shared in this link. http://www.chaoticdimension.com/forums/phpBB2/viewtopic.php?t=3526&highlight=grazing+sheep Link to comment Share on other sites More sharing options...
