paneli Posted February 26, 2011 Share Posted February 26, 2011 Hello, I found a picture with somebody making it, but unfortunatly he did not explained how. I want to randomize skew in Y axis multipy selected polygons (around 200 at the same time) Example added. Any ideas? :confused: I tried Orionflame 4 plugin, but the Sculpt Chaos modifier can not be accuratly defined. [ATTACH=CONFIG]41526[/ATTACH] Link to comment Share on other sites More sharing options...
Peter M. Gruhn Posted February 26, 2011 Share Posted February 26, 2011 If your model is contiguous, select all edges and Split. Put a poly edit on the stack. Use a random selection tool, I think Graphite has one. Add a noise modifier. Put a poly edit on the stack. Use a random selection tool, I think Graphite has one. Add a noise modifier. Do it until you are happy. Link to comment Share on other sites More sharing options...
sanmb Posted February 27, 2011 Share Posted February 27, 2011 Its always better to use simple and parametric method to avoid further complex model. Link to comment Share on other sites More sharing options...
paneli Posted February 28, 2011 Author Share Posted February 28, 2011 Its always better to use simple and parametric method to avoid further complex model. Parametric method? Link to comment Share on other sites More sharing options...
dande Posted March 1, 2011 Share Posted March 1, 2011 I came across this script the other day that might help. I haven't tried it myself yet http://www.reformstudios.com/maxscript/maxscript-curtainwall-wizard/ Link to comment Share on other sites More sharing options...
ulp Posted March 1, 2011 Share Posted March 1, 2011 meh, that could be handy! Link to comment Share on other sites More sharing options...
