Vray light help
kisuke_hc
hello there, im a newbie in 3ds max and i have a problem in vray light
as you can see in the image i attach, there are five vray light(i placed it on the ceiling) and one vray sun
when i try to render it, vray lights dont show, but the vray sun showed.
any helps are appreciated.
Don't appear on render? or not lighting your scene?
Just increase the multiplier until they do. Or play around with shutter speeds and f-number on phy Cam. You'll have to compensate the sun if you change the cam settings.
What are you suppossed to do, I do not know..
But I would suggest to learn about Max and Vray cameras. Daylight interiors through windows, doors and openings. About GI, since your picture showed you did not use it. Materials like wood, metal and glass and any a number of many more things. But you are in luck since we all were at one time or another where you are. Also, get in the habit of searching this forum for your answer before posting your question if at all posible. Why? Some things are just a quick answer but others are not and why would someone spend their time if you would not put forth any effort yourself?. There is so much to be learned here and browsing for answers that is almost unreal and through it all, if you do not experiment with your programs and or do tutorials, you'll be asking that which you should have known...
Welcome aboard
is vray sun suppose to be that orangy, or there is a way to make it more like a daylight?
Daylight systems are best used for daylight only. Mainly from 9:30am to 7pm during the summer months. It looks like you are getting closer to dusk, which in GI worlds usually mean you need to switch to a traditional digital light setup using a spot/direct/plane/etc... light to represent the light coming through the window.
@ismael yes i really want to learn, but i dunno where to start. i dont mean to be effortless or something like that, i am still in a highschool, so i dont have a lot of spare time, i learnt photoshop and i want to learn max too :)
i'll try to search for a basic interior tutorial, but if you have a good basic tutorial, its really appreciated :)
@homeless wow thanks i'll try to use it
Edited by kisuke_hc
