Daniel Doerksen Posted March 2, 2011 Share Posted March 2, 2011 Hey guys, be working on incorporating displacement maps into my workflow. i thought all was well until i did a test render. same material applied to two objects. why would the intensity of the disp map vary THAT much? Link to comment Share on other sites More sharing options...
Tommy L Posted March 2, 2011 Share Posted March 2, 2011 Have you scaled opne of the objects? Try an XForm on the scaled one, then collapse back to mesh. Link to comment Share on other sites More sharing options...
Daniel Doerksen Posted March 2, 2011 Author Share Posted March 2, 2011 Have you scaled opne of the objects? Try an XForm on the scaled one, then collapse back to mesh. Just tried that, no dice. I also tried duplicating the object scaling it down and increasing the texture size, still gives the same result. as you would figure it would since uvw works off of the uvw i think. Link to comment Share on other sites More sharing options...
Tommy L Posted March 2, 2011 Share Posted March 2, 2011 Have you played with the curve editor in just one map and no0t the other? Are you using VrayDisplacement modifier or displacement thru the material editor? Link to comment Share on other sites More sharing options...
Daniel Doerksen Posted March 2, 2011 Author Share Posted March 2, 2011 Just through the mat editor, didnt use the curve editor. and i was only working with one material for the stone. but what i did was attach both objects together and reapply the material and that solved it. im not sure what happened it would seem that it was using a old instance of the material. Appreciate the help as i figured out another problem with your help exporting to dwg for sketchup i wasnt reseting xform and it was causing missing faces. that was a problem i had awhile ago, jusst connected the dots now Link to comment Share on other sites More sharing options...
