casper18 Posted March 6, 2011 Share Posted March 6, 2011 hi guyz .. I'm a new MAYA user .. i have a mini map with buildings build on it. Can i import/export/convert .mb files into 3DS MAX? if yes, is there another software that i will use in order to do such things ? and what software or application will i use ? I REALLY NEED YOUR HELP ! Thank You in advanced ! Link to comment Share on other sites More sharing options...
JonRashid Posted March 6, 2011 Share Posted March 6, 2011 You can transfer as .fbx. The only thing to be wary of is smoothing groups do not exist in maya so will be lost Link to comment Share on other sites More sharing options...
casper18 Posted March 7, 2011 Author Share Posted March 7, 2011 ahmn .. how can i transfer it to .fbx ? what application will i use ? Link to comment Share on other sites More sharing options...
JonRashid Posted March 7, 2011 Share Posted March 7, 2011 You can export direct from Maya as an FBX file and import in Max Link to comment Share on other sites More sharing options...
casper18 Posted March 7, 2011 Author Share Posted March 7, 2011 MAx? are you talking about 3Ds MAX ? if i export direct from Maya as an fbx file, will i use Export All or export selected ? Link to comment Share on other sites More sharing options...
JonRashid Posted March 7, 2011 Share Posted March 7, 2011 Yes 3dsMax. You can choose what you want to export from export all to export selected - it's up to you. Then just go to 3dsmax import and your done. Link to comment Share on other sites More sharing options...
casper18 Posted March 9, 2011 Author Share Posted March 9, 2011 when i export all , there's no .fbx file type .. how can i export it ? Link to comment Share on other sites More sharing options...
JonRashid Posted March 9, 2011 Share Posted March 9, 2011 Maya 2011 has a .fbx output but you can try .3ds or .dxf or many of the other formats that Max can import. Just look at what Max can import and compare it to the list of what Maya can export. Link to comment Share on other sites More sharing options...
casper18 Posted March 9, 2011 Author Share Posted March 9, 2011 but only .mb .ma .move are the filetypes that i can see .. none of them fits in max .. how can i export then ? i really really need your help .. T_T Link to comment Share on other sites More sharing options...
JonRashid Posted March 9, 2011 Share Posted March 9, 2011 Go To window, settings/preferences and at bottom is plugin manager. You need to activate fbx and obj probably. This will then allow you to export those formats. Both of which can be read in by Max. Link to comment Share on other sites More sharing options...
casper18 Posted March 9, 2011 Author Share Posted March 9, 2011 ahhh .. thnx for the info ! ^_^ i'll do it ASAP .. and sir, if its ok with you, if i still can't do it . I will just reply to this thread for some questions and clarifications . Link to comment Share on other sites More sharing options...
casper18 Posted March 9, 2011 Author Share Posted March 9, 2011 thnx for the info ... hope this finally works .. i really need to convert my .mb files in maya 2011 to 3ds max so i can import it to Unity 3d .. its actually for my System ... ^_^ Link to comment Share on other sites More sharing options...
