Devin Johnston Posted March 7, 2011 Share Posted March 7, 2011 I have a glass curtain wall that is one object but I need to break it up so that each pane of glass is an individual object without spending hours detaching each pane of glass. Does anyone know of a script that will do this? Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted March 7, 2011 Share Posted March 7, 2011 toolTip="ExplodeElements to seperate objects" buttonText="ExplodeElements to seperate objects" --start macro --- maxscript ExplodeElements --- author: andrei kletskov (111) - http://andklv.narod.ru - andklv@mail.ru --- description: this script explodes ojects' elements into separate objects --- v0.1 - (22 july 2008) - initial version --- v0.2 - (20 oct 2008) - complete new algorythm in attempt to speed-up undo on ( coll = #() for obj in selection do ( try ( convertTo obj PolyMeshObject c = 0 while obj.faces.count > 0 do ( c = c + 1 el = polyOp.getElementsUsingFace obj obj.faces[1] polyOp.detachFaces obj el delete:true asNode:true name:(obj.name + "_EE_" +(c as string)) ) append coll obj ) catch ( print ("error processing: " + (obj.name as string)) ) ) delete coll ) Link to comment Share on other sites More sharing options...
Devin Johnston Posted March 7, 2011 Author Share Posted March 7, 2011 Dave that's exactly what I needed that's so much, did you write it? Link to comment Share on other sites More sharing options...
Devin Johnston Posted March 7, 2011 Author Share Posted March 7, 2011 Dave is there a way to get it to re center the pivot point of each object so that each new object has it's own center? Link to comment Share on other sites More sharing options...
Dave Buchhofer Posted March 7, 2011 Share Posted March 7, 2011 That was a found script one day when i was doing something similar, the guy has quite a few useful snips on his site (its in the comments of the script) after the fact to center pivots you can just run this script to do that: centerpivot $ I believe you can do it with the UI also, but i use it often enough that i made it a macroscript for hotkeying heh. Link to comment Share on other sites More sharing options...
Devin Johnston Posted March 7, 2011 Author Share Posted March 7, 2011 Yes your right the UI does all for this, thanks again! Link to comment Share on other sites More sharing options...
