phatwood123 Posted March 9, 2011 Share Posted March 9, 2011 I'm using rounded corners on the stucco on this house and it rounds the corners at the wall joints as well. the model is a .dwg imported from Revit. I don't know a lot about modeling in Max but I'm assuming this is something that needs to be done in Max instead of Revit. Any help would be appreciated. Eric Link to comment Share on other sites More sharing options...
sanmb Posted March 9, 2011 Share Posted March 9, 2011 Check by zooming in u will see joints intersecting or not properly aligned. snap vertices and u will get good result. Link to comment Share on other sites More sharing options...
phatwood123 Posted March 9, 2011 Author Share Posted March 9, 2011 It looks like the alignment is just fine when I zoom in. Maybe I'm missing something. I modeled in Revit and then imported so the alignment should be fine right? Link to comment Share on other sites More sharing options...
John Dollus Posted March 10, 2011 Share Posted March 10, 2011 If you are creating the rounded corners via material in Max, it's picking up on the edges of the element instead of the object. you will need to weld the vertices to get rid of the seam in that case. Link to comment Share on other sites More sharing options...
