Noise Posted March 9, 2011 Share Posted March 9, 2011 When I select a series of pieces of geometry I cannot group them. If however, I select one of those pieces of geometry and create a Group then individually Attach each of the other pieces of geometry I will then eventually end up with all the initial geometry I wanted as a group. Does anyone have a solution to this ? Thanks N Link to comment Share on other sites More sharing options...
Matt McDonald Posted March 9, 2011 Share Posted March 9, 2011 are the pieces part of another group which is currently open? You could try going to "group - close" and doing that until it is no longer an option then "group - explode". I also recall that with Max 9 (maybe) you could run into some weird instances where a group could be opened, the container deleted and then the objects from the group would could not be grouped together because max could not find the container. Link to comment Share on other sites More sharing options...
