Vray sky dome problem
popoff
Hi guys ,
I set-up scene with a sky dome using Vray - everything is OK , but when I try to put hdr in texture slot of the sky dome rendering became black ?!
[ATTACH=CONFIG]41829[/ATTACH]
Do you have any idea what`s wrong ?
File is here ( megaupload ).
:D
I load hdr from material map browser of max.
[ATTACH=CONFIG]41843[/ATTACH]
Max is not my primary 3d modeling / rendering software.
Can you please make print screen of "VrayHDRI loader" with options you used ?
Wich version of max you used ?
I placed VrayHDRI before , but I increased multyplier of the skydome not of the HDRI ( when HDRI is loaded skydome multyplier did`t work anymore ) ... however , there are my results :
[ATTACH=CONFIG]41848[/ATTACH][ATTACH=CONFIG]41849[/ATTACH][ATTACH=CONFIG]41851[/ATTACH][ATTACH=CONFIG]41850[/ATTACH]
Zdepth files became grainy when HDRI was used , do you got idea how can I improve their quality ?
Well I can uncheck "use texture" and render camera views with diffuse material ... but is there any other way ?
Once again thanks for your support !
