aristocratic3d Posted March 15, 2011 Share Posted March 15, 2011 Hi guys! I need to know how a 3D printer works. more important for me is how to create a 3d printable model from 3ds max? I heard about CNC machine. but dont know how to create a 3d model to use in CNC. help needed. Link to comment Share on other sites More sharing options...
JonRashid Posted March 15, 2011 Share Posted March 15, 2011 (edited) From max you export as an .stl file. Most software that comes with the machines can handle these. You cn also check the integrity of your file with stl check modifier. Edited March 15, 2011 by JonRashid spelling Link to comment Share on other sites More sharing options...
Noise Posted March 15, 2011 Share Posted March 15, 2011 Try looking at some of the manufacturers documentation, there are specific dimensions that you need to adhere to especially with fine detail, if you go below it the model will fall apart. Some times you might have to make some architectural details larger than they are so that they don't fall apart or break. Bear in mind also that people like to touch these things and can discolour or break the model - we used to put it in a presentation box to prevent this - it also looks much more professional. There is also the issue of modelling it in such a way that you are efficient with the print material for example, having a hollow base instead of a solid base. Internals to buildings will have to have structure so, include floor plates and support walls for rigidity. Other aspects are whether you have large areas of glazing defined by the framing or having it solid with a colour to depict the glass. Jon is right about the stl check modifier however the software for the print machine is the best way to check if the model is "watertight". Link to comment Share on other sites More sharing options...
aristocratic3d Posted March 16, 2011 Author Share Posted March 16, 2011 So how do you suggest me to earn experience or expertise in this sector. some of my client demand it but I am a real fool on that case. please suggest. Link to comment Share on other sites More sharing options...
lulu3496 Posted March 16, 2011 Share Posted March 16, 2011 agree Link to comment Share on other sites More sharing options...
anejo Posted March 17, 2011 Share Posted March 17, 2011 I outscource my 3d printing to my autodesk reseller. They're local so i'm able to pickup when the job is done. They have a zprinter http://www.zcorp.com/en/home.aspx (model number i don't know) but if you go to the website there's a lot of information there. Good Luck! Link to comment Share on other sites More sharing options...
